04-22-2014, 03:06 AM | #1 |
CLU KINGSMEN
29
Rep 566
Rotora BBK fitment confirmation
Okay brake gurus...need a little assistance.
I'm looking/thinking about purchasing these (Big Brake Kit 8 Piston Fronts 4 piston Rears http://www.m3post.com/forums/showthread.php?t=973703) for my E92. I currently have HRE P43's 19x9.5 fronts and 19x 10.5 rears with a +25 offset on all four corners. Would these fit? If these do not fit...what BBK size measurements can I go with? I was also thinking of going with the AP Radi-cal BBK set but cannot confirm what size Brake kit is compatible with my current wheel setup. And yes, I have contacted both AP Racing and the seller of the used BBK set...both have replied with "should fit" type answers. I just need a "100%" answer.
E92 M3 Satin Black GTS ModeCarbon Rimier MotorSports Premier Protective Films
HRE || RECARO || KW |
09-11-2015, 01:23 PM | #2 |
Rep 284
ive just installed my rotora 8 piston in the front i had to go up to 20' wheel since the stock zcp wheel wasnt giving enough clearence... im not sure if you will hjave the same problem, even thou the original owner seems to be on 19'' wheels
09-11-2015, 04:42 PM | #3 |
Rep 3,482
The AP brakes are a "sure fit" because they're a small footprint - huge braking potential type of set up. The caliper will be much slimmer than the Rotora kit. I'm +1 for AP racing.
2011 e90 M3 Space Grey DCT ZCP- eAs, BMW Performance, Agency Power, Macht Schnell, iND, Milltek, Volk, Challenge, Stoptech, Ohlins
BMWCCA:518970 |
09-21-2015, 10:08 AM | #4 | |
Rep 842
Here's a pic of someone testing one of our templates inside a wheel (a Corvette in this example): Our Essex/AP Racing Radi-CAL Pro5000R front kitswill start shipping in a few weeks. We'll have our front fitment template up very soon. That's the 100% sure way of knowing that they will clear. Finally, I'm not sure what your goals are with the car, but the performance of our setup is going to far eclipse any of the other options on the market. They may not be painted red and look quite as flashy, but they are by far the most technologically advanced offering available. |
09-25-2015, 07:03 AM | #5 |
CLU KINGSMEN
29
Rep 566
Thanks for the reply Markao & Amir
Essex- I will be contacting you soon. Thanks for the info.
