05-09-2014, 01:57 PM | #1 |
Rep 817
Drives: E30 M3 Darth Vader Trackcar
Helix or Alpine PXA-H800?
Which processor is the better fit for E90 with EPS? How good is the auto tune in the Alpine? will it auto tune while moving?
Plans are: Helix or Alpine with optical input from MOST-bus ($700) JL Audio 600/6 with Technic harness out to OEM wiring to speaker locations ($600) Focal separates up front ($430) remove HF drivers from rear doors and rear deck, turn off center MB quart under seat band pass ($219) JL 10-W3-4 sub in musicar enclosure ($225) Wiring and installation by me. Any advice on anything? Looking for SQ at 80mph as I live on the interstate 20hours a week. T |
05-10-2014, 04:29 AM | #2 |
Rep 206
Hi,
strong selection of components! If yo want to go the MOST way yo need the Mobridge to decode the signal = additional cost.. I would do this: Helix DSP w. Technic harness in from OEM wiring JL Audio 600/6 w. Technic harness out to OEM wiring to speaker locations Focal separates up front + MB quart under seat band pass OR -> Helix Match 3 way in the front (done one installation already - good) OR -> Gladen 3 way in the front (done one installation already - good) JL 10-W3-4 sub in musicar enclosure No need for the features of the Alpine when you anyway kill center and rear speakers. You should go full active with the 600/6 and take the time to lay extra cables to the front, it is worth it. Enjoy any solution you take, it will be a huge update! // Chris |
05-10-2014, 08:14 AM | #3 | |
Rep 817
Where can I buy the MoBridge online? What about the Match3 and Gladen separates? What do you mean full active on the 600/6? Separate channel to each driver and use the active crossovers in the amp as opposed to the factory designed passive crossovers that come with the components? I hate running wiring through that door connector so thats not going to work. T |
