New 2009 2010 BMW Z4 - ZPOST
      05-15-2014, 12:51 PM   #1
Asbjorn
Asbjorn's Avatar
China
90
Drives: Z4 N54 DCT (VTT GC lites)
M135i vs Z4 35i OEM/ESS
Video:
Results:
FIRST RACE - M135i clearly wins
2012 BMW M135i 8AT (Stock - 320hp/450NM/1525kg)
2009 BMW Z4 sDrive35i 7DCT (Stock* - 306hp/400NM/1605kg)
*Miltek de-cat mid-pipes installed
SECOND / THIRD RACE - Cars are almost equally fast
2009 BMW Z4 sDrive35i 7DCT (ESS - 355hp/480NM/1605kg)
FOURTH RACE - Z4 clearly wins
2009 BMW Z4 sDrive35i 7DCT (ESS - 390hp/550NM/1605kg)
Settings:
M135i: Sport+ & Manual Shifting (Launch in 2nd Gear always)
Z4 35i: Normal & Manual Shifting (Launch in 2nd Gear except
second race)
      05-16-2014, 09:50 AM   #2
Nkc
NOOB
Nkc's Avatar
Drives: Cars
thanks for the video. Very informative and gives a great comparison with the ESS tune.
@BMWclassicdivision
      05-17-2014, 03:43 AM   #3
Alext
Drives: B M W
Basically stage 1 ESS tune is similar output to 35is tune from factory. Imagine the 390HP tune + FBO!
      05-17-2014, 12:00 PM   #4
Asbjorn
Asbjorn's Avatar
China
90
Yes, given that the M135i was running as it should, the video confirms that the 35i with ESS stage 1 performs similar to a 35is.
I am still not sure if the 35is makes 340hp at all times, or only when overboost is NOT activated. ESS stg 1 gives +15hp and +30nm over the 35is when running without overboost... On the other hand, the 35is produces +20nm over ESS stg 1 when running with overboost.
According to fastestlaps.com the 35is and M135i are more or less equally fast below 100mph. Above 100mph the Z4 pulls ahead, probably due to better aerodynamics and slightly higher peak hp.
This is also what the video shows... that the Z4 ESS stg 1 is faster than the M135i at higher speeds, whereas at lower speeds the gearing/driver becomes the deciding factor (the 8AT and lower weight of the M135i makes it very fast at normal road speeds).
      08-20-2014, 03:13 AM   #5
J Lau
J Lau's Avatar
Drives: E46, E82 ,E89, G30
very nice!
That's what I call a good "vs." video.
Thanks a lot!
zpost
