05-24-2014, 03:28 PM | #2 |
Rep 3,990
Yes, completely normal. I can see that you just washed your car. I found a great thread about it and this is what many members had agreed upon: "Rust on brake rotors is totally normal. It will form every time you wash your car and let it sit after. This happens with any car that has steel rotors which is 99.9999% of all cars with disc brakes." So, the best solution is to usually drive it a bit right after to let the brakes heat up and dry off for it to go away.
Here's the thread if you want to verify yourself . http://www.bimmerfest.com/forums/sho...d.php?t=248010 PS: Awesome wheel choice
2014 X5 50i X-Line // Mineral White
05-24-2014, 05:52 PM | #5 | |
Rep 10
05-24-2014, 09:03 PM | #7 |
Rep 3,990
05-25-2014, 12:18 AM | #9 |
Rep 29
Those are called rotors, and it's completely normal after a wash or even if your truck has been sitting still after a rainstorm. Once you start driving (and then braking), the rust will be scraped off by your brake pads.
