06-02-2014, 02:46 PM | #1 |
Rep 6,732
19" BBS LM...
Always a catch huh It's only half of a set. One front and one rear. BBS LM 19x8.5 ET32 BBS LM 19x10 ET25 Michelin PSS Tires Front 245/35ZR19 XL Michelin PSS Tires Rear 265/35ZR19 XL If it makes you feel better, I have three more wheels that will come with it. One rear that had some work done to it so I replaced it One front and one rear that has a cracked barrel but might be able to be used for parts (center and rivets) Might be good for spares for someone. I'm still not sure I want to buy replacements and have a complete set or just sell at a loss I'm thinking of $1500 OBO for all of it. I'm in Nor Cal http://s979.photobucket.com/user/fle...eshow/BBS%20LM Last edited by BzsBimmer; 06-08-2014 at 10:17 PM.. Reason: Sold |
06-02-2014, 03:09 PM | #3 |
Rep 6,732
I just got hit with several PM's... teaches me to post at McDonalds while at lunch...
I'll post pictures up after work today. For additional clarity: Both LM's that are functional have tires. The tires have very good tread on them as they were almost new. There is some dragging on the tread when the car was put on to the flatbed but that's about it. The two that were on the car that are damaged... the outer ring is toast. The only thing I would consider using them for is the center and the BBS rivets. The last rear I have had a crack or something in the outer ring. I only found out about it was when I went to have the lips polished and the wheel shop told me. Fail on my part when I bought them from the original owner. I just replaced that wheel, and then subsequently cracked it on a curb. There are x3 BBS LM 19x10 ET25 (One still has the tire on it but probably too damaged) x2 BBS LM 19x8.5 ET32 (One still has the tire on it but probably too damaged) x1 Michelin PSS Tires Front 245/35ZR19 XL x1 Michelin PSS Tires Rear 265/35ZR19 XL Again, I'll post pictures of everything. |
06-02-2014, 03:43 PM | #4 |
Smashed!
84
Rep 1,309
Drives: 2009 E92 M3
in for pics....
est. 2008
BBS | BREMBO | RECARO | ig: @euro_rad |
06-03-2014, 12:10 AM | #6 |
Rep 6,732
Photobucket link attached
After looking more closely, I think the best thing to do is sell the front and rear as listed. The people who want the bits and pieces of the other wheels will need to either buy as is or come see it. I wasn't planning on selling those, was going to include them if buying the half set. I'm not a wheel expert. There are some small paint cracks which means the metal was bent in some way. I can't see for sure if it's fixable etc. I'll ship but a) I don't have a tool to remove the rivets from the center b) there are still tires on the wheels and needs to be removed by a tire shop Now you could take the tires and if you have tire replacement warranty, could claim those. I didn't have any tire warranty. The tires are pretty much new. The wheel that has NO TIRE is drivable however there is a small leak somewhere. I was filling up the tire every few days or so. I'm throwing fairly new BBS lugs as well as the rear centering rings and metal clips. If I get full ask, I'll throw in an extra black BBS center cap AND 4 BBS caps in red w/ gold lettering. |
