06-17-2014, 11:38 AM | #1 |
Rep 76
Michelin PSS - Mercedes? Rear Fitment
So about to get some new tires...heard that the PSS dont come in the standard sizes...looking on tire rack there is a porsche and mercedes 265/35/19 Tire...anyone have a clue if this is ok (other than merc heresy being on my car)? I want to rock the standard fitment.
http://www.tirerack.com/tires/tires....e&autoModClar= |
06-17-2014, 11:50 AM | #2 | |
Rep 3,070
"The mark of a great car is one whose overall competence exceeds what you should expect from its individual components and the 1M does just that", Chris Harris.
BMW 1M-SOLD-: TECH: Evolve Race+N55mids, Evolve IC, Michelin PSS, ER cp, aFe filter, CDVx, Vorshlag camber plates, BMS OCC EXTERIOR: trunk spoiler, blacklines, black grills, IND goodies INTERIOR: Alcantara steering wheel, steel pedals, custom mats, MPower e-brake. |
06-17-2014, 12:14 PM | #3 |
Rep 11,785
More than likely there are two tires.
The OE spec tire for the merc/Porsche and the tire for all. Perhaps one of them is out of stock temporarily and that's why just a single listing. ? |
06-17-2014, 07:07 PM | #4 |
Rep 898
Drives: '69 GT3, GT4, 1M, 912
They have an N0 Porsche spec tire in that size too (and it's cheaper), but I'd go with the Mercedes tire. The Porsche is for front fitment on a Carrera GT, and you'd prefer to use a tire not designed for the front. I've used the Merc spec tire with no issues, also the previous standard spec, don't think I can tell the difference.
1M, GT4, 1969 Porsche 911 w/ 997 GT3 Cup Motor (435hp & 2,100 lbs)
06-24-2014, 11:13 AM | #5 |
Rep 1,668
I had the back tires (PS2) replaced by new PSS........and I don`t like them at all, unstable at high speed and quick steering responses makes the car very loos at the back, very very hard to control.
Now I`m going back to PS2 tires I was surprised the new PSS had a MO mark on them; meaning Mercedes Original ! |
06-24-2014, 11:59 AM | #6 | |
Rep 3,070
I have a full set of PSS since more than 14,000 km. and high speed unstability is the last criticism that would come to my mind, on the contrary. I am talking about up to 266 km/h (GPS reading) high speeds by the way.
06-24-2014, 11:59 AM | #7 | |
Rep 898
06-24-2014, 12:11 PM | #8 |
Rep 1,668
Yes, but no one told me not to do so. I wouldn`t be a problem I was told.
The MO mark I was told there where no other PSS available ! No BMW PSS 265 with a * mark on them Anyhow; I`m replacing all 4 tires now; PS2 just the way it was, just the way I like it. All at a descent discount, the dealer should have known better, I too |
06-24-2014, 12:16 PM | #9 | |
Rep 381
Just food for thought, but the PSS's also come with slightly deeper tread depth than the PS2 tires. 8.5/32" vs 10/32" (rear). It's not much but that's a 18% increase. Combine that with wear on your front tires and different construction you might end up with different slip angles than you were used to.
06-24-2014, 12:20 PM | #10 |
Rep 1,668
I have contacted Advevo, who is a friend of mine. He told me the PS2 has more driving stability than the PSS.
That judgement is more than enough for me, all 4 new PS2 are coming back ! Yes I know now; the mixing was not the most clever thing to do, the dealer should have warned me, the front had 4mm left, so not immediate need for replacement! It will not happen again, I can assure you ! Did I tell overhere I have a Porsche Cayman GTS on order? ETA 2nd-3th week of August, Sapphire Blue, PDK, all the driver goodies on it..... Oh, the 1M is staying :-) Last edited by Romo; 06-24-2014 at 12:42 PM.. |
06-24-2014, 12:34 PM | #11 | |
Rep 898
Bad idea to mix short and long relaxation length, as you found out. However for reference when I replaced only my rear PSS and kept the old fronts I had exactly the opposite behavior. The sticker compound of the fresh PSS at the rear caused terminal understeer... I've always replaced all four since.
